Anyone have any problems with their numark NV. Such as, sometimes one deck not working properly or the scratch function not working etc.? If so have y'all found a way to correct the problem?
Posted Thu 13 Aug 15 @ 7:40 pm
Okay,are u using the built-in native mapper? do you let you computer update? the only problem I had was the sound and it was the drivers.I found out it does'nt like the usb plugged to a usb hub.it must be directly plugged to your computer....
Posted Fri 14 Aug 15 @ 10:42 pm
