on my numark nv when i press slicer loop in Serato DJ it turns on a 8 bar loop
sadly vdj does not do this and i use it alot
how can i add this mapping to my numark nv . i want to set it to where i can turn off the loop by pressing the same button
Posted Tue 21 Jul 15 @ 8:22 am
Even if a script is provided to trigger a 8beat loop, it wont work the same as the Serato Slicer loop mode. Reason is that VirtualDJ doesnt offer quantize for loops, so the loop will be probably enabled earlier or later to the beginning of the slice.
Posted Tue 21 Jul 15 @ 12:56 pm
dam Vdj VirtualDJ 8 Dont crash on me when i do my Net radio show or even my Videos on youtube . i hope that vdj add this soon .
is there any skin that will let me control 3 fx with my Nv
maybe even remap the loop area like my set up would be 4 8 16 32 64
this is how i had it in mixvibes and my launchpad :)
Posted Tue 21 Jul 15 @ 7:57 pm
user11353228 wrote :
feel free to steal this :)
ok so where do i go to do that and sry i did not get back to you in time i have been working alot
Posted Fri 31 Jul 15 @ 7:17 pm
We have removed the mapping file the previous user has posted, since it has nothing to do with either the NV or the Slicer Loop question of the OP.
Posted Fri 31 Jul 15 @ 7:27 pm
o ok
Posted Fri 31 Jul 15 @ 8:19 pm
