Can anyone help me to map Traktor Kontrol X1 MK2 touchstrip sliders in Virtual DJ 7.4? Mapping from VDJ8 doesn't work.
Posted Tue 21 Jul 15 @ 1:56 am
It can't get mapped.
VirtualDj 7 misses the code to handle the touchstrip properly. So you can't map it as a touchstrip. You can barely map it as a single slider, but I don't see any use at this...
Posted Tue 21 Jul 15 @ 10:25 am
Thank you. This is good to know.
Posted Tue 21 Jul 15 @ 2:44 pm
All I needed is some kind of jogwheel function. I'm using VDJ remote android app for that. Its pretty good.
Posted Sun 09 Aug 15 @ 5:55 am
The touch strip can be used as "jog" in VirtualDj 8. As I said previously, VirtualDj 7 lacks the code to support it and as we all know it's out of development.
Posted Mon 10 Aug 15 @ 3:28 pm
