Topic: Vdj 7.6 and Denon mc6000mk2 sound card issues
I'm not new to vdj 7 but I am new to the controller. Deck 1 works fine. Deck 2 no sound output. I am chasing the pitch control. Every song it want to automatically change. I'm not using the sync button but it appears it is doing this on its own. 8 does the same thing with pitch. Audio works on deck 1&2 fine.
Posted Thu 02 Jul 15 @ 11:51 pm
hello guys i have a problem in my virtual dj 8 in my mac if i connect my hercules controller it works for only 30minute
allprodjken about your pitch Go to config +options + audio tab find autoBPMMatch change to no ,also if you wanna use desired pitch use of 10% for every song: go to config.+ options autopitchrange change to no, and now your pitch won't go lover than 10% or more then 10%
You issue has nothing to do with this subject. Please do not hijack a thread, start your own.
