trying to figure out how to work my controller so I can mix without music playing through my monitors. I have a NUMARKNV & I'm not sure what to do to utilize both features. any input is gladly appreciated.
Posted Mon 22 Jun 15 @ 3:53 pm
60 views no replies? wow. Thanks guys!
Posted Tue 23 Jun 15 @ 5:01 am
follow this setup guide that's available on the wiki for anyone who looks https://virtualdj.com/documents/Numark%20NV%20-%20VirtualDJ%208%20Operation%20Guide.pdf
then your headphones should work and u can forget about the sandbox its kinda useless when u have 4 decks anyways
side note the headphones will need to be plugged into the NV not your PC
Posted Tue 23 Jun 15 @ 5:10 am
Thanks sir! i have this manual
Posted Tue 23 Jun 15 @ 2:33 pm
@ djkuz
ok, so you got 60 hits and nobody could answer your question!
1. your question was not specific enough
2. you expect that we can solve all of your problems for you
3. please read the manual first, understand that sandbox only really works when you're using 2 decks and not with a controller ... in 4 deck mode you can forget it!
so, first learn how to manage vdj, invest the time to learn, then ask questions and we'll help you where we can.
ray
ray
Posted Tue 23 Jun 15 @ 4:21 pm
