Hi everyone. I use VDJ7 and use the Phaser editor to line up the beat with the squares. I am using VDJ8 now and want to use the custom button to use the phaser tool for my songs. What is the phaser titled under in VDJ8 so I can use the custom button for it? All help is appreciated, thanks.
Posted Fri 12 Jun 15 @ 8:29 pm
Yeah sure you can, two buttons like so
adjust_cbg -0.1%
adjust_cbg +0.1%
adjust_cbg -0.1%
adjust_cbg +0.1%
Posted Fri 12 Jun 15 @ 11:03 pm
Awesome, sorry I am new, is there a video instruction on how to add this to make it work?
Posted Sun 14 Jun 15 @ 5:03 am
Oh thank you, it is not that hard to figure out. Except, is it possible to add both (-) and (+) to the same knob so if I go one way it does (-) and if I go another it does (+) ? Thank you.
Posted Sun 14 Jun 15 @ 5:12 am
for a knob -> param_smaller 0 ? adjust_cbg -1% : adjust_cbg +1%
this is on an endless encoder knob on my controler
Posted Sun 14 Jun 15 @ 12:39 pm
