Forum: VirtualDJ Skins
Topic: v8 Remote skins - Page: 2
You cant have mini decks + Browser in the Remote, so the Mini Decks panel of the "views" group has to go out completely.
Anyways, here is what you need to do...
- line 1548 : change the action to browser
- Delete lines 5840 - 6270 (the entire "browser" panel
- Delete line 1561 & line 5837 (will make the "decks" panel always visible
It is suggested to name the skin with a different name in case you may want the same skin to be used as main skin
Several things will not work properly (such as songpos markers, Scratch grids and cue markers, wont show any video of course.
hi has any body made a skin of just a mixer for virtual dj remote i am trying to make a touch screen setup using virtual dj remote on 3 ipad airs and am trying to get a single deck on 1ipad with a mixer skin on the second ipad with another single deck on the 3rd ipad i have added a picture of what i am trying to accomplish. it dose not have to be exactly what is in the picture its just an example
Hi everyone!!
i got a problem with my Remote 8 Default Skin
sometimes i have many button from the skin together
like that
someone have a solution
( i'm french and sorry if i don't have read again last post 'cause i'm more in french speaker's )
After a little playing with the Skin Builder and some code tweaking and ive now got a great little remote for VDJ8
Though the horizontal waves appear slightly out on the remote vs same skin on the PC (default skin dosent do that though)
one i edited from the 2 deck tablet skin by DjKaos2012 into a 4 deck display and browser for the remote app
Can Someone Please Make a Skin for a 10inch Tablet that is just FX Units and selectors with a touchpad. No Need for timelines as I have that on the screen in front of me, in fact, I have all of it on the screen in front of me and on my controller. all I need is FX for Channel 1 and 2. or if it is easy to edit and existing one this would help also as one of them is ok it just lags out due to the time code running on it
a link or a site where i can download these skins please
www.virtualdj.com/plugins/ if you're asking about legal skins for the VDJ Remote.
sorry i can not give links too the skins i posted in this thread as i do not have permission to share from the skins creator and it has been impossible for me to track one author down to ask him if i could submit them too virtualdj.com so unfortunately the cdj-2000 and djm 900 skins i converted for the virtual dj remote will not be published or shared
There is nothing illegal about the skins ideas i posted
I asked in the forum before i started trying to customize any skin if it was ok too do so
And was told there was no issue with me doing it as long as it was for my own personal use &
1,i do not try to claim them as my sole idea and creation
2,if i want too submit them i have too have the authors permission first
3,i can not try too make money by selling them as it is a copyright violation
As i have not done any of them 3 things they are not illegal
I get the feeling you have a problem with me and i do not know why
Almost every post i have ever made in the forum you have had an issue with,
Your advise is welcome and appreciated but trying to make me look like a bad person to everyone who reads what i post by dropping hints that i have broken some site rule or done something illegal in your comments is out of order
.....and I didn't say there was. He asked about skins in this thread, which doesn't necessarily refer to yours anyway.
I can't down load the skin to my iPad . I have the remote but want to use the sampler skin any help would be great .
dj dad rock star!
Is there a way to use a different skin instead of the default Remote 8 skin for android devices (Galaxy Tab E) better yet what steps do I take to create a custom skin?
Nevermind,,, just simply copy the zipped skin file to the iPhone folder.
Back again..... how do you apply custom scripting to the Remote default skin? I would imagine through the .XML file but there are numerous .XML files so I tried deleting them one by one to see which one the tablet was using so I knew which .XML file needs modified but every time I tried to load it, it failed saying that there wasn't a page.
65%
