I really think that the brake effect on VDJ8 sucks. I really enjoyed the one featured on VDJ7. is there anyway i can get that plugin on VDJ8?
Posted Fri 05 Jun 15 @ 12:51 pm
Why what is wrong with it? Please elaborate "X sucks" is useless as a criticism.
Have you tried slip brake8?
https://virtualdj.com/plugins/?addonid=80246
Posted Fri 05 Jun 15 @ 1:02 pm
Set RampStopTime to 0.7
hit stop sound like any other stop FX I've ever heard
Posted Fri 05 Jun 15 @ 4:13 pm
The only complaint I can see with V8's native brake FX is that it doesn't slip if you get the double tap in before the fx stops, like it did with V7.
Which slip brake8 accounts/allows, but I have run in to 1 fix that is needed but it's a rare event.
(note to self; if you use a function check it before activation.)
Posted Fri 05 Jun 15 @ 6:10 pm
