Hey I need to know how to reprogram the master wave form color (on top of the screen)
I need to change at least one of the colors from red to yellow or some other color so I can actually see it better?
Does anyone out there know how to change/ reprogram this?
Or change the deck colors? This would be very helpful for people who suffer from color issues :/
Posted Tue 05 May 15 @ 2:46 pm
rythm wave colors cannot get changed in default skin unless you change the skin xml.
to change waveform of the decks please see settings/ options/ coloredWaveforms.
but there are various skins in the dl area who are able to
Posted Tue 05 May 15 @ 2:56 pm
Thanks I will look to see if I can find those. Do you know which ones
Posted Tue 05 May 15 @ 2:57 pm
OrangeJuce and Controller Skin by DennYo
for example ... but sure a lot more can ... dont have testet all skins yet :-)
Posted Tue 05 May 15 @ 3:40 pm
Right on Thanks for the help.
I decided it would just be easier to have windows Invert the (display colors or High Contrast mode)
Posted Wed 06 May 15 @ 3:11 pm
