Topic: iphone remote & VDJ8
after the 2 recent builds my iphone remote is not showing up in the remote tab. enable devices is selected. any thoughts? Thanks
Posted Tue 05 May 15 @ 2:38 pm
I just tried with my iPad. It did not find the device. I removed the device and then enabled it again. Now it works.
With mine it doesn't show the iPhone as a device like it did before. ???
Have you verified they are on the same network and that the firewall permissions are still okay?
Are you using version 8 or 7?
problem solved had to use hardwire...bluetooth wouldn't respond. thanks for your help. cheers
Glad it worked out.
