Hello all,
I am having trouble matching my organized iTunes library to VDJ. The way that my iTunes is organized is by genre. When I try to pull it up on my VDJ it is not organized at all and they are songs missing.
Any tips/advice on how to fix this problem? Thank you.
Posted Tue 05 May 15 @ 8:08 am
I use iTunes to manage my music due to me having multiple idevices for phones and back up audio sources.
I created (or there was) a smart playlist in iTunes for recently added. Every time I add music in iTunes, I check that playlist to see this have been added. When I go to VDJ, I go to that playlist. I then use the 'not scanned' smart folder int the 'tools' section of the 'My Libraries' add on to show me the music that's not scanned. I select them all and scan the BPM.
For the first time you may need to navigate to your iTunes music folder in VDJ, add and recourse it, then go to 'not scanned' and scan things that have been missed.
Posted Tue 05 May 15 @ 10:14 am
