Plz im going to xdj-rx for pub use i was wondering if it is compatible as midi controller woth vdj8 thnx
Posted Sun 12 Apr 15 @ 8:44 pm
Dj sam jad wrote :
Plz im going to buy xdj-rx for pub use i was wondering if it is compatible as midi controller with vdj8 thnx
Posted Sun 12 Apr 15 @ 8:45 pm
Also well the wave forms shows on da screen?
Posted Sun 12 Apr 15 @ 8:46 pm
I'm waiting for the software the have to reveal for the rdj RX. I'm using it as stand alone mixer right now. I'm really curious!
Posted Mon 13 Apr 15 @ 10:10 pm
Here is current list of supported controllers, https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
Posted Tue 14 Apr 15 @ 8:52 am
Unless your mixing video I really don't see the point of VDJ supporting this unit??
I mean RekordBox is a solid program and all you have to do it throw all your music on a drive that isn't partitioned (Rekordbox will only read the first drive).
And even then there is a way just connect your laptop to the unit and play through Rekordbox.
Posted Tue 14 Apr 15 @ 10:17 am
