whats going on guys i remember sometime ago virtual dj had this feature when you set hot cues for songs they would countdown to the next hot cue so you knew how long it was before each hot cue. example would be you set a hot cue at beat one then you set another hot cue lets say 30 seconds into the songs. the time from hot cue 1 and hot cue 2 would be 30 sec and VDJ would tell you that and it would countdown the time before each hotcue so i could time my transitions nicely. any one know if this feature is still in the application? thanks
Posted Sat 11 Apr 15 @ 5:03 pm
Posted Sat 11 Apr 15 @ 5:12 pm
yes how do you get it to do that?
Posted Sat 11 Apr 15 @ 5:15 pm
i got it thanks bud just had to lick on the hot cues hahah im slow
