Topic: Hercules RMX2 settings
HI! I just got the Hercules RMX2, and the settings for my other Hercules aren't working. I use my HP laptop, and Hercules RMX2 into a Mackey Board. What should I set my config to? Currently the sound is coming out of my laptop only, but the Hercules is working to control things. Can anyone tell me what to set my config settings to?
Thanks in advance!!!!!!!
Posted Fri 10 Apr 15 @ 7:48 pm
Can you give a list of all audio devices VDJ lets you choose from?
Hello Faifer,
If you use your DJConsole Rmx2 audio inputs in VDJ 8, you can set the audio like this:
Output Speaker + Headphones
Card Hercules DJConsole Rmx2
Input Line Input
Master DJConsole Rmx2 OUT 1 & 2
Hedphones DJConsole Rmx2 OUT 3 & 4
Line In 1 DJConsole Rmx2 IN 1 & 2
Line In 2 DJConsole Rmx2 IN 3 & 4
If you use only Rmx2 audio outputs, you can set it like that
Input Nothing selected
