Topic: Key detection default setting to display note
Is there a way to keep the key detection showing the note instead of the number? (standard skin)
Even if I change it's not stored when I close VDJ8.
Posted Thu 02 Apr 15 @ 3:38 am
Only if you change/edit the skin.
Unzip the VirtualDJ 8.zip file you will find in Documents/VirtualDJ/Skins folder and open the 2 Decks.xml file with a Text Editor.
Search for .. get_harmonic
You will find 2 "blocks" that look like..
<textzone>
<pos x="+433+31" y="+63"/>
<size width="32" height="15"/>
<text size="15" color="#E1E1E1" align="left" action="get_harmonic"/>
<text size="15" color="#E1E1E1" align="left" action="get_key"/>
<text size="15" color="#E1E1E1" align="left" action="get_key_modifier"/>
</textzone>
Change the order of the lines so that the one you need to be displayed by default is 1st
Save, update the zip and relaunch.
Great!
Thanx for fast and precise support!
This is the reason why I love VDJ. It can be changed and edited to suit everyone's needs through the skin and controller mappings.
Happy easter!
