I get the following message when starting Virtual DJ:
Error in the ASIO Sound Driver: Your soundcard is probably not connected, or the settings are incorrect.
How do I correct this problem?
Posted Sun 22 Mar 15 @ 4:27 pm
I assume that you do actually have an ASIO audio interface, and that you have installed the manufacturers original ASIO driver...
So, when you start VDJ - is the interface physically connected and powered? Are the settings correct for the number of inputs & outputs that the interface has available?
It would be helpful if you stated which ASIO interface you have, and posted a screen grab of your VDJ audio settings.
Posted Sun 22 Mar 15 @ 4:45 pm
This message usually comes if sound card not supported...
Posted Mon 23 Mar 15 @ 6:43 am
If the computer and operating system support it (i.e. there's a driver available) then VDJ supports it.
Posted Mon 23 Mar 15 @ 1:30 pm
