Would it be possible to use the crossfader on my Denon X500 mixer and assign it to control the volume of sampler output in VDJ?
The mixer has a X-fader output jack and my controller, Denon HC4500 has an input for it.
But how do I mapp it?
Posted Thu 12 Mar 15 @ 2:46 am
Long story short: You can't :(
And the reasong you can't is that this control is used as a switch so that the HC4500 knows if the crossfader is all the way to the left or all the way to the right.
Typically this cable is used to start/stop the decks when the crossfader reaches one end or the other...
Posted Thu 12 Mar 15 @ 3:01 am
Thanx for a quick reply.
So, the problem is that HC4500 does not care about the x-fader position, but rather end points?
But VDJ does have support for it?
Posted Thu 12 Mar 15 @ 3:19 am
Well, I have to correct you :)
It's fully working as I wanted, after a bit of investigation.
The crossfader position is read by HC4500 and I assigned it to control Sampler Volume. (Since it's working to control video I thought it must be possible to control sampler)
But it seems for now I can only adjust the sample 1 volume even if I used sampler volume master command
Posted Thu 12 Mar 15 @ 4:38 am
LOL. It's been a long time since I stopped using my HC4500. Perhaps I confused it with fader start control (Fader 1, Fader 2)
Anyway, so you used "sampler_volume_master" as your command and it doesn't affect the volume of all samples ? Are you using VirtualDj 8 ?
Posted Thu 12 Mar 15 @ 6:26 am
Sampler_volume_master does not change the volume of any samples.
I'm using VDJ 7.4.2
I'm using VDJ 7.4.2
Posted Thu 12 Mar 15 @ 8:00 am
This action is available in version 8 only.
In version 7, all you can do is to control the Volume of each sample slot independently or the default/selected one
with either sampler x volume or sampler default volume
Posted Thu 12 Mar 15 @ 9:27 am
Even If I manually select for example sample 3 , the volume slider change in sample 1.
Aha! I found something strange..
I have assiged the hot keys 1-5 to play samples. And when I press one of those keys the relevant tab in sampler mode goes green as it should.
But it does not change in the main window (default skin)
I need to change the sample in the small window - then the volume knob changes (and the slider in the sampler mode) changes. Bug?
Posted Thu 12 Mar 15 @ 12:54 pm
i think you need to also select the sample
So for your sample buttons, you need something like...
sampler x play_stop & sampler x select
Posted Thu 12 Mar 15 @ 1:38 pm
You were quicker! Thanx - will try this! :)
Posted Thu 12 Mar 15 @ 1:41 pm
I love the script commands of VDJ :)
Posted Fri 13 Mar 15 @ 5:27 am
...even if it did not work as it did yesterday.
Today - even if selecting a sample with the hot keys (sampler 1 play & sampler 1 select) the slider won't adjust the sample in focus. Just sample nr.1
But, then I tried with the crossfader to add: sampler 1 volume & sampler 2 volume & sampler 3 volume , will adjust all levels. A good solution?
Could it be something that affects which deck is active for the moment?
Posted Fri 13 Mar 15 @ 6:24 am
Sorry for the "thread-bombing" but I am close to what I want.
(You guys should really have a separate section of the forum about mapping stuff)
Now it works in this way, the crossfader affects the volume on the selected sample on left deck.
But, if I play a sample on the right deck, only sample 1 volume is adjusted (even if another sample is selected)
How Can I do this "deck independent" ?
One final mapping related question:
How do I change PFL with a command, to be able to see the graphical waveform "in top"?
Posted Fri 13 Mar 15 @ 9:10 am
try to add deck active before the sample actions.
So something like ..
deck active sampler default volume
but without deck definition, sampler x volume should work fine regardless if the sample 1 is triggered from deck left or right.
for the "graphical waveforms" can u be more specific ? Which skin do you use, which waveform do u want see at the top ? (screenshot would help)
Posted Fri 13 Mar 15 @ 9:24 am
Sorry, I mean the moving blue and red waveforms in top of the default skin.
I need a way to select which deck is "active" through my HC4500 controller.
Posted Fri 13 Mar 15 @ 9:46 am
i suppose any key that is available on both sides of your controller and mapped as .. select, should do the job.
Posted Fri 13 Mar 15 @ 3:38 pm
