Where can I find serial number for purchased license?
My Account --> My Licenses --> You currently have this license: VirtualDJ 8 CONTROLLER License for AAVMS4
Posted Thu 19 Feb 15 @ 9:53 am
Just log into V8 (I think) there are no serials with V8.
Posted Thu 19 Feb 15 @ 9:56 am
Version 8 doesnt have any serial numbers (keycodes). Your purchased licenses are now visible in your Account and all you will need to do is to login with your virtualdj.com account's credentials to the Login window of VirtualDJ when it pops up or from the Config->LICENSES tab.
Posted Thu 19 Feb 15 @ 10:00 am
Ok, undrstand, but my computer for music make is "cutted off" from network (no antivirus installed, no firewall etc) and is not possible to run VDJ8 without connecting to network. Is a big problem for me. When I power off this comp, and power on next day - same problem - without network I can't use full VDJ8
Posted Thu 19 Feb 15 @ 10:54 am
You only need to connect the computer once, to generate a license "key file". After that, VDJ will not require a connection, because it just checks for the file when it starts.
It's also a good idea to make & keep a backup of the file once you have it.
Posted Thu 19 Feb 15 @ 11:00 am
The copy and keep method doesn't work, (I've tried it) there must be some hidden witchcraft afoot.
but if OP is serious, it never goes online then there isn't any reason for insurance.
Posted Thu 19 Feb 15 @ 11:31 am
How to generate license key file? I can only put license key info free place - no option for key generate.
Posted Thu 19 Feb 15 @ 12:33 pm
Log in, go to options, find the option "stayLoggedIn" set this to yes, Close VDJ, Reopen VDJ, If you never go online with your gig machine, You should not have to log in ever again.
Posted Thu 19 Feb 15 @ 12:46 pm
Thnx, now everything works fine without active network connection.
Posted Sun 22 Feb 15 @ 7:47 am
