thank you so much guys.
I really appreciate your help, mixing from intro to outros, that's the only thing I can do for now. I'm going to practice some drops in the middle of the songs as you said.
you're all a great help..
I'm so grateful to join here.
Posted Sun 15 Feb 15 @ 11:17 pm
Are you making good use of cue points?
If you have a listen to some tracks which you know are popular, try setting some cue points where something dramatic happens - such as a big drop.
You can name cue points too, so you will be able to see what each one is and when it's coming up. That'll help with transitioning at places other than the beginning & end.
Posted Mon 16 Feb 15 @ 6:29 am
And don't be shy of using loops. 8/32
Posted Mon 16 Feb 15 @ 6:51 am
I admire you for doin this. I would'nt have had the b**ls to do it back then.
my best advice to you is to go with the flow, enjoy your music, make your heart sing ...
break a leg
ray
break a leg
ray
Posted Mon 16 Feb 15 @ 4:21 pm
