Forum: VirtualDJ Skins
Topic: #SilverSleek2 - Page: 12
Hmmm. I'll have to experiment but I believe it's possible...
Posted Sat 23 May 15 @ 5:45 am
1. this sort of restricted search has been aked for already, if you could do this you would be the man!
2. back to the beat phraser, I like to have my CBG on the 1, 'cos it avoids train crashes, long story. I need to see where the sw has placed the 1 ... I have so many songs that are all wrong & have to correct them all before i fade away. So i need a visual 123412341234 and thought that maybe you could put it in the middle ring here ....
and here's the big one, I'd like the first beat to be at 3 O'clock, and I hope this won't become another direction thing ... lol
Posted Sat 23 May 15 @ 2:29 pm
I stole this from Bob 😜 but could we get this on the iPad verison and possibly the skin as well,
I do have some of my samples color coded and plan on using the iPad version for the effects, loops, samples, blah,blah and have the max browser on my laptop.
Posted Tue 26 May 15 @ 10:20 pm
dcomoPRO InfinityMember since 2012
I used this skin this past weekend and it was perfect. The only thing that I found that needs adjusting is the dropdown arrow targets are still too small and instead of dropping the menu, it activates the effect. (Backspinning at the wrong time doesn't sound good!)
I also suspect the the middle panel for just the mixer (without scratch waves) is still a placeholder. (Nothing appears other than a blank panel.)
Posted Tue 26 May 15 @ 10:25 pm
The Central Panel offers 4 views at this point (1 is incomplete and visible by my mistake :P)
So definately not an empty placeholder
Edit:
Aaah. Yes.
The "Full mixer" is not complete yet and it should not be visible as an option yet (my mistake)
It's 50% implemented for 2 decks, but 0% for 4 decks...
Posted Wed 27 May 15 @ 12:26 am
I'll try to tweak sampler pads view more
Posted Wed 27 May 15 @ 12:27 am
Don't get me wrong if it's already ready I'll take what you got now 😜
Posted Wed 27 May 15 @ 12:34 am
The skin allready has sampler pads
But they don't behave like this.
So I'll try to tweak them.
However it's possible to fire samples from the pads
Posted Wed 27 May 15 @ 2:52 am
I found a bug with the FX.
Steps to produce:
1. Select Single FX and Echo
2. Switch to MultiFx
3. Switch back to Single FX
Result:
There is only one Knob for controlling the Echo and it doesnt react to midi-Commands anymore.
Edit:
If you switch between Single and MultiFx with Clicks in the Skin all works fine, I switched with my controller, only then the problem happens.
But all in all the Skin is awesome, just what I needed.
Keep up the good work!
Posted Fri 29 May 15 @ 4:14 am
Found the bug!
It wasn't the skin, its a bug in the mapping of the DDJ-SX2 for the Shift-Key:
it is: set '$shift' 1 while_pressed & set '$shift' 1 while_pressed
but should be: set '$shift' 1 while_pressed
Posted Fri 29 May 15 @ 7:16 am
TrueJoshua wrote :
Found the bug!
No, it should be:
set 'shift' 1 while_pressed & set '$shift' 1 while_pressed
I will fix the mapper! :)
Posted Fri 29 May 15 @ 7:18 am
George is the man! :-)
Posted Fri 29 May 15 @ 7:38 am
@Phantom,
Any screen shots of the iPad companion??
Posted Thu 04 Jun 15 @ 11:40 am
Soon! I guess by now you know what's coming up! ;)
Posted Thu 04 Jun 15 @ 3:23 pm
Haha I had no clue when I posted this 😂😂
Can't wait to get home an see what's crackin!!
Posted Thu 04 Jun 15 @ 3:39 pm
POLL time!!!
A:
or
B:
Edit:
For those who wonder what's this all about:
Posted Mon 15 Jun 15 @ 10:11 am
"A" - The markers should be behind.
Posted Mon 15 Jun 15 @ 11:23 am
A
Posted Mon 15 Jun 15 @ 11:47 am
I think your best option is to provide both.
If you only pick one, someone will complain that they want the other!
Posted Mon 15 Jun 15 @ 11:55 am
Either is fine for me, but I suppose A (behind) is better as it doesn't obscure.
Posted Mon 15 Jun 15 @ 12:23 pm
46%
