Here's my problem;
I am using 3 different pc's(2 laptops and a desktop), not all at the same time, I have a laptop at home, a laptop in my studio and a desktop that will one day become my gig pc.
how can I synchronise these all together, so that if I make some changes on one or the other or the other, it will take effect on all of them?
I used to use synctoy 2.1(echo) but it's hard to keep up with all the changes.
I'm not really savvy with computers, so I could need some advice in simple terms.
thx in advance
ray
thx in advance
ray
Posted Wed 04 Feb 15 @ 7:51 pm
store music on a usb drive use it with them all :-)
Posted Wed 04 Feb 15 @ 8:19 pm
hi wicked
but that means that I would have to carry a hdd around with me all the time and plug it into each pc. I'm looking for a way to keep them all in sync, 'cos sometimes I run 2 at a time at weddings where I have 2 areas etc etc etc
edit
I think i need something like a central base, so that it doesn't matter from where I make the changes, it will be updated on all of my machines
edit
Posted Wed 04 Feb 15 @ 8:55 pm
as long as the systems are not connected physically or via somekind of cloud, you will have to plug a device in some way to keep them sync
Posted Thu 05 Feb 15 @ 1:39 am
I just use an external HDD and Synctoy (echo)
Works for me, but I tend to use only one machine for gigs, updating music, database etc. Then echo it to the others.
Posted Thu 05 Feb 15 @ 1:51 am
Thx for the info gentlemen, I'll keep workin on it, gonna try out robocopy next.
Posted Thu 05 Feb 15 @ 4:12 am
The USB Drive can be your master that you sync to each Computer and can also serve as a backup.
not a perfect solution but unless you have a home network to sync the computers over and the know how to do that i think the other option should be pretty simple.
Posted Thu 05 Feb 15 @ 4:16 am
I think your right wicked, up till now I've used synctoy(echo) but it's a one way street and I'm changing things on to many pc's to keep up with it.
thx again
thx again
Posted Thu 05 Feb 15 @ 4:48 am
