Hi everyone, major bug here...
¾ of the time I use the "Smart play" function, the song either starts ahead or behind it's cue position and completely messes the mixes.
I tried every settings possible without any success.
This happens on every Virtual DJ versions.
Posted Sun 25 Jan 15 @ 12:28 pm
Please check your autoCue Settings in the Options Tab
Posted Sun 25 Jan 15 @ 12:54 pm
I did, numerous times. Nothing changed.
Posted Sun 25 Jan 15 @ 12:58 pm
...what is your setting first beat/ skip silence or no ?
Posted Sun 25 Jan 15 @ 1:03 pm
autoCue = first beat
Posted Sun 25 Jan 15 @ 1:15 pm
which one of these three you have set ?
Posted Sun 25 Jan 15 @ 1:17 pm
First beat, skip silence no.
Posted Sun 25 Jan 15 @ 1:28 pm
audio tracks all scanned/ re-analyzed and added to database ?
what happens when you disable smart start ?
Posted Sun 25 Jan 15 @ 1:38 pm
The problem when you have Smart play disable is that you have to be 100% accurate on the Play button. Kinda "risky".
My database is uptaded yes, all my audio tracks are in it. But do I really have to scan/re-analyzed them? You think that may solve the problem? I have about 4000 songs in my music folder, so it may take quite a while...but if it's necessary I will do it.
Posted Sun 25 Jan 15 @ 1:51 pm
just try with a couple of them :-)
Posted Sun 25 Jan 15 @ 1:55 pm
Good, thanks. :)
Posted Sun 25 Jan 15 @ 2:02 pm
I re-scanned/added to the search db my Chicago House Music folder and I still have the same problem.
Oh well, thanks anyway.
Posted Sun 25 Jan 15 @ 2:24 pm
cue points importet from V7 db ?
Posted Sun 25 Jan 15 @ 2:30 pm
CBG correct? Quantise setting?
Erm yeah we called that what you call "risky", djing,
Posted Sun 25 Jan 15 @ 2:43 pm
When I installed Virtual DJ 8 yesterday and runned it for the first time, the folders from my old Virtual DJ 6.0.7 Pro were already there. I did not change/import anything manually.
Some of the tracks are cued at the exact same place they were in Virtual DJ 6.0.7 and some are not. Franckly, I don't understand a thing. LOL
By the way, I'm sorry for the quality of my written english, I'm french canadian. I'll try to adress my problem on the french forum.
Regards
Regards
Posted Sun 25 Jan 15 @ 2:45 pm
@locodog
I Dj since 1979, learned it the hard way with vinyls and turntables (belt/direct drive ones). I worked in a few clubs here in Montréal, still make gigs once in a while (weddings, corporate events). But with Virtual DJ it's just not the same feeling.
Here's my Mixcrate page : http://www.mixcrate.com/cyberwing
Posted Sun 25 Jan 15 @ 2:51 pm
When you launch V8 for the first time, database will be automatically imported.
Add some new songs to V8. Set some cue points and check if issue still present.
Possibly there is something wrong with the import of old cue points.
Posted Sun 25 Jan 15 @ 3:08 pm
But I already had the same problem with version 6.0.7 Pro.
Funny thing is, when no song is playing on the other deck, all starts are ok with Smart play on.
Weird...
Weird...
Posted Sun 25 Jan 15 @ 3:41 pm
Posted Sun 25 Jan 15 @ 5:38 pm
please check also if you have autoBPMMatch set to "no" in V8/ Settings/ (advanced) Options Tab
Posted Mon 26 Jan 15 @ 1:57 am
