One of my laptops (new) is running Windows 8.1, my other an older one, is running Windows 7. How I wish I had never bothered with 8.1!!
My old lappie is set up with User Name Jules, but I set up the new one as Julian. The problem is I want identical filepaths for my playlists etc on each computer, and so I want to change my User Name and filepath on the Windows 8.1 machine to show Jules. I thought it would be straightforward but apparently not.
Can someone help please as to how I can arrive at having, for instance, an Itunes filepath looking like this on both machines:
"c:\Users\Jules\Music\ItunesMusic\...." on both machines.
Posted Tue 20 Jan 15 @ 10:31 am
Can't you just create a new user called Jules, with admin rights, then delete the old user from the new one?
Posted Tue 20 Jan 15 @ 10:34 am
Flatten the 8.1 machine and install Win 7.
Posted Tue 20 Jan 15 @ 10:43 am
I added a User Jules with Admin authority and rebooted. At the root of C there remained just one option 'Julian'. Bamboozled completely by W8.1. I have since disconnected from my MIcrosoft sign in (new users beware) and added Jules as a 'Local' and still the User Jules does not appear under Users on the C drive.
Posted Tue 20 Jan 15 @ 10:46 am
It's an absolute nightmare to change the primary user name. I've seen lots of threads on other sites and they all recommend the nuclear option.
Posted Tue 20 Jan 15 @ 10:56 am
Is this info any use?
http://superuser.com/questions/747564/how-can-i-change-username-in-windows-8-1 (scroll down)
Posted Tue 20 Jan 15 @ 11:02 am
Thanks for your replies guys and it is reassuring in one way in that the problem is recognised but disappointing that I've spent nearly £600 on a laptop that frankly I need to nuclearise and start again. By the way Locodog, what exactly do you mean by go 'nuclear'?
Groovindj, ...yes I found that earlier thanks but wasn't keen on obviously experienced techies arguing over the best way to do it; I am going nowhere near the Registry.
I just can't believe that HP/Microsoft sell a laptop that is so obviously inflexible.
Posted Tue 20 Jan 15 @ 11:22 am
Completely format it and install windows 7
You can avoid doing that, but it means registry editing and it isn't easy, even then you have to keep up to date with 2 o/s' If you don't like 8.1 why keep it?
Posted Tue 20 Jan 15 @ 11:35 am
ok thanks, understood.
Posted Tue 20 Jan 15 @ 11:50 am
Or use the inbuilt recovery to reformat the machine and set the username correctly :)
Posted Tue 20 Jan 15 @ 12:47 pm
Far more easy solution:
Use junctions since your drive is NTFS formated.
Junction is an "alias" for a folder and it's transparent to the OS.
Imagine it as a shortcut to a folder...
Mklink /j c:\users\usernamefromoldlaptop c:\users\yournewusernameonnewpc
Done!
Done!
Posted Tue 20 Jan 15 @ 2:08 pm
u could always just make a folder under c and u could have c:/music on both pcs no issues at all
no need switching users or anything
i think sometimes we get caught up using those premade areas and forget we can make our on folder anywhere we want :-)
Posted Tue 20 Jan 15 @ 2:22 pm
Mklink /j c:\users\usernamefromoldlaptop c:\users\yournewusernameonnewpc.
Done!
Done!
Great, now I have a whole new avenue to research. I assume you will have to treat one path as a 'master' in regards to what is written to the database and m3u lists.
I have not had issues with 8.1. I would hold off on nuking it. Microsoft does not go backwards in future OS support. Plus, there is no resaon to go purchase 7 when you can get 8 to play nice. You just have to work through the differences.
Are you trying to use the same paths for backup purposes?
Posted Wed 21 Jan 15 @ 12:57 am
