Topic: How to config my controller (numark mixtrack edge)
Hello, I have purchase a numark mixtrack edge that I will receive soon. I want to use with Virtual DJ. The controller has only 2 knobs of EQ. The software has 3 knobs. ¿How can I mix correctly with this? ¿How can I assign 2 knobs to 3 bands of EQ?
Thanks you so much 4 the answers
Posted Thu 15 Jan 15 @ 4:28 pm
If the headphone volume knob is sending a separate Midi Note when pressing the shift button you can try to create a additional key S_EQ_HIGH an use the action "eq_high" as long as you are using a Pro or a plus controller licence.
Home Free Version will support your controller only 10 min after each launch of VirtualDJ.
