can someone tell me how I CAN GET ON vdj radio
Posted Mon 05 Jan 15 @ 3:52 pm
Just need to apply here:
https://virtualdj.com/forums/101881/Virtual_DJ_Radio/HOW_TO_BE_A_DJ_ON_VIRTUALDJ_RADIO.html
Posted Mon 05 Jan 15 @ 3:56 pm
is it possible to stream to more than one Server/ port number i.e. I currently use Simplecast software to stream my show to our station. The stream is done on various bitrates e.g. 192, 128, 64 each bitrate size has a separate port number (using the same IP address) thus enabling the show to go to each port. As far as I can see in the VDJ broadcast setup you can only stream to one port - is this correct?
I want to use VDJ to broadcast as its the easiest option for me plus track tags are displayed on listeners devices which whilst not critical is a plus.
Posted Fri 09 Jan 15 @ 5:23 am
Not possible to simulcast for now, but maybe a feature to add ;)
Posted Fri 09 Jan 15 @ 10:44 am
