Topic: external hard drive
Hi guys I have finally backed up my music to a second hard drive but all my virtual folders/ short cuts do not appear when I use the new one help thnx robert
Posted Mon 22 Dec 14 @ 10:17 pm
All informations about your music and folders are stored in the virtualdj database. This also includes name of the complete path of each file.
Make sure that you new drive has the same drive letter and uses the same folder/ path structure as your previous one.
Thnx yes it does however gonna try copy it again
Are you backing up using the file operations system built into VDJ. If not you should use this as it copies over everything. Try right clicking on a folder in VDJ and selecting File operations and copy to your external drive.
