I was hoping somebody could help me out here. I was wondering if the Serato CV02.5 Control Tone is supported. I searched, but didn't find anything on it. I am using Cue 7.4 if that makes a difference. Thanks.
Posted Tue 16 Dec 14 @ 11:50 pm
hello
Yes if the CV02 Serato vinyl are compatible CUE 7.4 Serato vinyl CV02.5 will also be compliant, the signal does not change, just the gain increases.
On VirtualDJ 7.4 & 8 they work fine
Posted Wed 17 Dec 14 @ 3:53 am
Thank you Lylian
Posted Thu 18 Dec 14 @ 12:57 am
