Can it? I'd like to use a cue point to send a MIDI note to my lighting software as a trigger. Didn't see anything in the manual about it.
Posted Thu 04 Dec 14 @ 10:15 am
Which version of VDJ do you use ?
Here gives for the DMX-Lighting Software Freestyler some VDJ Plugins,one is named with :
SBDJ FreeStyler Cue v1.0 and SBDJ FreeStyler S2L v1.3,but this Plugins are the Old Version,
think you must use this so:
For VDJ 7 use the Freestyler 2.0 Plugin
https://virtualdj.com/addons/15834/freestyler.html
See this thread for more information:
https://virtualdj.com/forums/137181/VirtualDJ_Plugins/SBDJ_FreeStyler.html
For VDJ 8 Pro Infinity use the Freestyler 8 / 3.1 plugin:
https://virtualdj.com/addons/16835/freestyler8.html
Information is available here:
https://virtualdj.com/forums/191352/VirtualDJ_Plugins/freestyler8.html
greatings,Dirk
Iself have not work or test all this Plugins,
will be later test it when i have a DMX Interface
greatings,Dirk
Posted Thu 04 Dec 14 @ 10:40 am
Thank you for the reply. I use v8. Should've mentioned that, my bad.
Posted Thu 04 Dec 14 @ 10:45 am
Howcome i'm not able to see the page to download the freestyler8 plugin?
I have vdj8 pro license, so i should be able to use all plugins, shouldn't i?
Thanks for any help...
Posted Sun 14 Dec 14 @ 6:41 pm
You should probably start your own thread.
Posted Sun 14 Dec 14 @ 6:46 pm
Seems that the link is old...
Try this one
https://virtualdj.com/plugins/?category=other&search=freestyler
Posted Mon 15 Dec 14 @ 5:32 am
