HI, Fellow DJ's,
DDJ-SB Question
I have joined the online community after years of suffering ... hahahaha ... I have successfully created a rock solid version 7 system on PC and now want to update my skin to the new DDJ-SB controller I moved up to. Can anyone out there help me or supply one or help in anyway?
Behringer NOX-606 Question
I also needed a small but decent controller/mixer other than the DDJ-SB and liked the reviews and features it had for the price. I would like to find a skin for that and use it for other decks, CD's and so-on. It has a SB interface but how do I control it thru my PC?
Thanks in advance
for any help
DJ Davey D
DDJ-SB Question
Thanks in advance
for any help
DJ Davey D
Posted Sun 16 Nov 14 @ 10:54 am
There is a DDJ-SB skin in the download section.
As for the mixer, I don't think it's very likely you'll find a skin to match. Most skins either have their own distinct style or they are designed to resemble controllers - not mixers.
You mean a USB interface? That's only an audio interface. You can't control it (the mixer) from your PC, or (as would be more usual) control your PC from the mixer.
Bear in mind that when using a real mixer, there is no need to use or control the on-screen "virtual" mixer.
PS It looks as if the mixer does have MIDI - but only on a DIN socket, and only 6 of the controls are connected to it.
Posted Sun 16 Nov 14 @ 11:19 am
