Topic: Pleas Help: browser big boxes how to remove
sorry, forgot how to remove this big boxes for each song.
Want to see the good old list of songs like in VDJ7
It´s easy but I can´t find it.
Can anybody help?
Posted Fri 07 Nov 14 @ 9:54 am
User manual, page 37.
If you're using touch screen mode, you don't have the choice.
Thank You groovindj BUT
I even hav´nt the choice in Mouse mode.
In the Manual I found out, this view is called "grid view" instead of the "list view.
In options I voted it out:
But there are always these big grid-views, no list view
And neither in tablet mode nor in mouse mode.
When I start VDJ8 again there is "yes" for grid mode again.
The Manual shows for the browser options:
but I see only:
in tablet and in mouse mode - it doesn´t matter.
How can I rid of it?
Any Ideas?
Built 2028.861
Select "display list as", and select list view.
As You can see in my last post:
ME AND MY build 2028.862 DON´T HAVE A "display list as"
So what can I do?
If the option is not on the menu, then you must be in touch screen mode. The only time that menu option is missing is when you are using touch screen mode.
Try deleting (or renaming) your settings.xml and then open VDJ 8.
Thanks GrovvinDJ!
Thats it.
Just deleted the "settings.xml" and the option apears again.
Everything´s fine.
Nevertheless: Would this be something for the Bug-section of the Forum?
Thank You All!
