Hi Chaps,
First post so be gentle :-)
just putting together a new console whats the best way to configure the connections so I can access both VDJ and Rekordbox on the Macbook ?( bearing in mind I will be using this mobile so trying to make everything plug and play without having to remove any panels)
If I'm reading the info right
CDJ 1 & 2 via a separate USB to Macbook = Virtual DJ
CDJ1 & 2 via seperate Cat5 via 5 port hub to Macbook = Rekordbox
presumably with phono's/Digital into DJM from each CDJ
So on my console I will need 2x USB and 1x Cat 5
Do I need anything to the DJM ?
or.................Am I reading the whole thing wrong
I appreciate I will need to change the settings on the CDJ to midi but trying to make sure all the leads are in place
Cheers chaps
Regards
Les
Cheers chaps
Regards
Les
Posted Thu 06 Nov 14 @ 8:28 am
No flippin idea why my user name is like it is either ?
Posted Thu 06 Nov 14 @ 8:36 am
Hi, I had a little go with CDJ200s and virtual dj a while ago. I made this video about it not sure if it's any use to you but just so you can see it's pretty straightforward.
https://www.youtube.com/watch?v=2tcaj1p1HnQ
The only thing I can spot that you mentioned is that you won't need a separate network hub, the djm2000 has a 4 port hub built into it. So you'll just need 2 usb cables (or 3 if you wanted to use the midi controls on the mixer or record your finished mixed back to the PC) and 3 cat 5 cables. Two to connect the cdjs to the mixer, and one to go from the mixer to the pc for recordbox control.
Hope that helps.
Hope that helps.
Posted Thu 06 Nov 14 @ 9:35 am
Same connections on a mac, but you'll need to install the pioneer soundcard agrregator software to make it all work together. And you'll probably need a good usb hub since you might have 3 usb cables.
Posted Thu 06 Nov 14 @ 9:36 am
Cheers for the info Andy, that helps.
Regards
Les
Regards
Les
Posted Fri 07 Nov 14 @ 1:59 am
