Hello! I'm a new dj (If you could call me that.). I'm 16,I play at home using vdj home (like a noob.) and use a Gemini g2v. I have some Deadmau5, Skrillex and a lot of Hardcore and Metalcore. So yeah, the basic info about me. Feel free for to add advice and stuff.
Posted Wed 05 Nov 14 @ 6:16 pm
Nothing wrong with being a noob. Everyone was a noob at one time.
Posted Wed 05 Nov 14 @ 9:19 pm
it's awkward playing with 2 decks to me. The beats are off even though the bpm (128.00) is the same. Huh?
Posted Wed 05 Nov 14 @ 9:26 pm
@sololu
Give this post a read, just some basics. http://www.virtualdj.com/forums/6288/Mix_lessons/DJ_MIXING___basic_-_advanced_-_pro.html?page=1
Welcome!
Welcome!
Posted Wed 05 Nov 14 @ 9:31 pm
Thanks! SO MUCH INFORMATION! Yay!
Posted Wed 05 Nov 14 @ 9:38 pm
Beatmatching nailed!
Posted Fri 07 Nov 14 @ 9:00 pm
Problem..... one of my feet on the bottom of my controller came off. Should I try to find it and glue it back on or leave it as it is?
Posted Mon 10 Nov 14 @ 11:31 am
Well...........take a minute to think about it, and then you decide what will work best for you.
Posted Mon 10 Nov 14 @ 3:04 pm
I decided to leave it.
Posted Tue 11 Nov 14 @ 8:58 pm
What sort of Hardcore are you into? Gabba, Speedcore, Hybrid, Breakcore? I've probably know a lot of artists I could switch you on to.
For example
https://soundcloud.com/biohannya/weyheyhey-little-batty-foo-foo-biohannya-edit
For example
Posted Wed 12 Nov 14 @ 8:01 am
Om&m, Bmth, Ptv(?) That's pretty much it. Metalcore.
Posted Wed 12 Nov 14 @ 5:54 pm
Hmm, I like a bit of metal and am familiar with Om&m (from years backbut the -core suffix must be a different meaning your side of the Atlantic.
I blame those crabcore jokers.
Posted Wed 12 Nov 14 @ 7:39 pm
aye up all any advice how 2 sort me sound out
Posted Fri 14 Nov 14 @ 1:40 pm
You're gonna have to give us more info than that.
Posted Fri 14 Nov 14 @ 1:42 pm
lol ok im using the free version its using wasapi an I cant get it 2 sound right cant I jus use my soundcard without wasapi
Posted Fri 14 Nov 14 @ 1:47 pm
its doing my head in I cant get the volume I can move the volume faders on both decks and the volume wont change
Posted Fri 14 Nov 14 @ 1:49 pm
any help would b great on what the problem is
Posted Fri 14 Nov 14 @ 3:41 pm
'ow do, you can't be far from me, what with you starting a post with "aye up"
I think we'll need a pic of your Audio config (like so)
http://pbrd.co/1zpKbmG
Posted Fri 14 Nov 14 @ 5:14 pm
do you know how I can install the sampler effect because im running windows 8.1 and the file it use is not saported how do I use that formate is there a softwear I can use
Posted Fri 14 Nov 14 @ 5:30 pm
how do I use the sampler the formate is in correct and im using windows 8.1 is there a softwear I can use
Posted Fri 14 Nov 14 @ 5:32 pm
