Hello, maybe someone can help me to deal with sound. I have a small speaker(in the speaker there is AUX IN and LINE OUT), and also I have headphone. On laptop there is 1 output for sound and one for microphone. How should I connect and do in settings(Virtual DJ 8) that, I could prelisten with headphone? Thank you for any help, I hope you understood.
Posted Mon 03 Nov 14 @ 5:41 am
Unfortunately you will have to purchase a second USB sound interface in order to be able to use both speakers and headphones with your laptop since it only provides one sound output (but you need two)
Posted Mon 03 Nov 14 @ 6:08 am
Posted Mon 03 Nov 14 @ 10:24 am
If mono is ok you could use something like this 3.5mm/ 8th inch male stereo to 2 female mono.
http://www.maplin.co.uk/p/nikkai-connect-35mm-stereo-to-2-mono-splitter-l39ba?gclid=Cj0KEQiA7NyiBRCOhpuCm9Dq6b4BEiQA9D6qhb8-Fbk2BMlIQuQ6oAH_8tpTVSL-TmMhCx2aGS9WiiAaAvgv8P8HAQ.
don't use maplin though, they're extortionate. £3/$5 is the usual price for such a cable.
Posted Mon 03 Nov 14 @ 10:44 am
Hi,
What you need is a Virtual 7.1 soundcard, which you then configure to suite. This will allow you to monitor the sounds through your headphones. You can get this from Amazon or ebay.
Posted Wed 05 Nov 14 @ 12:18 pm
