Topic: Advice on Opening VDJ7 & 8
Could someone advise me if it's ok to have both VDJ7 & VDJ 8 open at the same time?
I'm doing a gig where the club is using VDJ7 and from a response on the forum a couple of days ago I was advised that all my cue points, anchors ect from VDJ8 are not backwards compatible.
As I am pretty much using a preselected set list for 2 hours so I want to copy over things onto the tracks in VDJ7 manually - unless there is an easier way to do it that is ?
Thanks Guys
Posted Fri 31 Oct 14 @ 8:13 pm
So, your not looking to gig like that just make set lists and cue points ahead of time? If that is the case, back up your databases, and try it.
I can't think of labour saving way sorry it looks like it will have to be manual.
