Hi
Does anybody know, how to open the little playlist window at the down-right-side with a shortcut?
(VDJ7.4.1)
I´m using a touch screen and the button is sooo small.
(another skin is not the solution cause I have to use my own one)
The answer is not "playlist load" - it´s just about to open the littlie playlist-window.
Thanks for all ideas:
(VDJ7.4.1)
Posted Sun 26 Oct 14 @ 7:50 pm
This is my modified skin (thanks DJDad!) But this doesn´t matter - its VDJ7.4:
And if You go with Your Mouse over this Button (the "playlist"-one) ...
... the playlist window opens.
How can I do this per shortcut (A Key-Mapping)?
Thanks for any help
Thanks for any help
Posted Sun 26 Oct 14 @ 8:54 pm
Any Ideas?
Posted Mon 27 Oct 14 @ 4:29 am
why you don't lock it?
Posted Mon 27 Oct 14 @ 5:53 am
No, unfortunately version 7 doesnt offer any control (actions) to open/close the Playlist window. You should consider upgrading to version 8 and enjoy the tools offered for Touch screens.
Posted Mon 27 Oct 14 @ 6:16 am
Hi jmf28: Cause I need the space in the middle. (Thank You anyway)
Thanks DJDad, I´m waiting for the next big update of VDJ8 to start with it.
For the moment 7.4.1 seems more stable for me.
So Thank You all!
So Thank You all!
Posted Mon 27 Oct 14 @ 6:28 am
