kteam wrote :
Yes, I am experiencing problems with Mac Yosemite and my current version of Virtual DJ 7.2 LE - Mac (b412). No song loading and error displayed on both decks.
Please Help!!! Thank you
Posted Thu 30 Oct 14 @ 7:52 pm
Yes, I have the same problem with i updated iTunes, just a few days ago
Posted Thu 30 Oct 14 @ 7:53 pm
Plan C, you can drag your song directly from itune to VDJ7 and work all the time. The only bad thing is you dont know if you already play a song (turn red). Im waiting for a fix to play directly itune12 playlist just like before !
Posted Tue 11 Nov 14 @ 6:17 pm
I went into Config - Codecs added one called iTunes and used the Internal Audio Decoder then switched m4a to the Internal Audio Decoder... It seemed to have fixed the issue for me... Hope that helps.
Posted Fri 28 Nov 14 @ 1:15 pm
yes im having the same problem but my decks load but no soundcard in audio midi setup
Posted Sun 07 Dec 14 @ 2:49 pm
