How do I get my effects to fade out automatically.
Let's say I want to do a 1 bar echo and then want it to fade out how do I get it to do this?
Posted Sun 12 Oct 14 @ 9:53 am
use the echo doppler. set it for one beat, turn up the feedback and it will fade out, like the pioneer efx 500 and 1000.
Posted Wed 15 Oct 14 @ 3:22 pm
I downloaded the Echo Out and it doesn't fade it kind of "crunch" sound at that point. Is the Echo Doppler effect in the download section or you talking about the included samples and effects with VDJ 8?
Posted Thu 16 Oct 14 @ 3:06 am
No echo Doppler is not a stock effect
Posted Thu 16 Oct 14 @ 3:34 am
The Echo Doppler is in the download section.
Posted Thu 16 Oct 14 @ 4:40 pm
if its a transition effect with the music stopping and it echoes away, also try loopout or flanged loop out
Posted Thu 16 Oct 14 @ 5:11 pm
Did in this set LIVE on the radio.
http://virtualdjradio.com/djsets/djset.php?mixid=8957-2
Posted Fri 17 Oct 14 @ 10:45 am
