Hi.
I was searching on Google for a different controller mapper to work with Virtual DJ 8 as I am not happy with the one that it uses, unless someone can help with this issue, when in Vinyl mode, using the jog dials I find it really slow searching for the first beat of the song. In Virtual DJ 7 you could change the values of the jog wheel but I don't see this in Infinity 8. If someone can help with this issue please can you explain. I also came accross a dodgy website while searching for a Mapper, I was not too sure about posting the link here as the forum is public, and I did not want to promote the sale of Dodgy Software.
Who do I contact to let Atomix know about this site.
Posted Sun 12 Oct 14 @ 4:07 am
config/options/controllers/jogSensitivity...
Posted Sun 12 Oct 14 @ 4:14 am
I would think that the best mappers for VDJ, are found on this site. Another great feature is the ability to map the controller to do whatever you like. Did the previous suggestion help you? You can report the site here, and have one of the staff members take a look. They can always level it up.
Posted Sun 12 Oct 14 @ 3:25 pm
DJMikeJames wrote :
Yes i did find the controllers config, but I do noy know what to set the values to.
1.0 (default value) means 1 rotation of the jog equals 1 rotation of a real turntable.
Setting it higher will make it more sensitive. 2.0 Will make it twice sensitive, meaning that 1 rotation of the jog on the controller equals 2 full rotations of a real turntable = 2 rotations of the jog on your screen.
You can experiment with this value to find out what suits your needs
Posted Mon 13 Oct 14 @ 11:55 am
