Topic: Effects default settings
Hi, is it possible to reset the effects parameters to factory defaults without affecting any other settings?
Posted Sat 11 Oct 14 @ 1:25 pm
Double-click on the Parameter knobs in the default skin, should reset the values to default.
You could also delete the .ini files you will find in the VirtualDJ/Plugins subfolder.
