I have a Macbook Pro running on Virtual DJ 7 Pro and I'm using the Hercules 4Mx Controller. My controller seems to lag and some of the buttons on it are hard to activate. I find myself at gigs almost abusing the buttons lol and I'm not sure as to why there is such a delayed response from the controller. I've been using the laptop view of the skin to crossfade and loop and do other things instead of using the controller. The jogwheel response is pretty rough also so I hardly scratch because its delayed so bad. Anything I can do to fix this, could it be the controller that has an issue? Doesnt seem like it because there are no signs of defects or anything. Please provide some input and I greatly appreciate it. Hope I described my issue well.
Posted Sat 11 Oct 14 @ 1:15 pm
Any info???
Posted Mon 13 Oct 14 @ 2:17 am
there are some settings in the Hercules Control panel regarding the latency/buffer i think.
Posted Mon 13 Oct 14 @ 10:24 am
You might want to try optimizing your computer, as described in the following document:
http://ts.hercules.com/faqs/eng/her_eng_00363.pdf
Posted Tue 14 Oct 14 @ 10:31 am
