Hi , can anyone help with the commands when starting virtuadj to make it start with multi mode effects selected instead of single mode and also to make it save the selected effects when closing and re-opening the program
I'm just learning about the commands available but have no clue with this one
thanks
thanks
Posted Thu 02 Oct 14 @ 9:25 am
what skin do you use?
Posted Thu 02 Oct 14 @ 10:47 am
Hi, I use the standard vdj 8 skin
Posted Thu 02 Oct 14 @ 10:58 am
there isn't this funct on the skin standard
Posted Thu 02 Oct 14 @ 11:19 am
If you mean the 4 decks skin, then the action for the ONINIT key of your keyboard or controller should be ..
set '$fx1multi' 1 & set '$fx2multi' 1
for the 2 decks skin, software will display the last used panel, but you can still force the 3 FX slots one if you use ..
skin_panel 'sidebar_left_fx' on & skin_panel 'sidebar_right_fx' on
Posted Thu 02 Oct 14 @ 5:03 pm
