Not really sure but try to hold shift+play button while turn the ddj sx on to disable demo mode.
Posted Mon 20 Apr 15 @ 2:07 am
Page 23 of your SX2 manual.
You need to start the unit in "Change Settings Mode"
Hold down SHIFT+PLAY/PAUSE buttons on left side and power on the unit.
Release SHIFT+PLAY/PUSE
Press the "Autoloop" button on RIGHT side until the "LOOP 1/2" button is ON
Power off the unit.
Power off the unit.
Posted Mon 20 Apr 15 @ 2:27 am
guys,
I'm thinking i have maybe lost the plot here but i can't find the english user manual for the sx2 on the pioneer site. got the quick start etc but not the user manual.
any help would be great.
Iain
Iain
Posted Sun 26 Apr 15 @ 5:02 am
Posted Sun 26 Apr 15 @ 11:34 am
Hello my friends.
Using ddjsx2 under Mac with last VDJ version.
Is possible timecode with sx2 and VDJ 8?
If yes? how can i setup it?
Whith serato you can use DVS with sx2 (After paying taxes)
Thank's a lot.
Thank's a lot.
Posted Mon 27 Apr 15 @ 2:47 pm
Posted Mon 27 Apr 15 @ 2:58 pm
A lot of thank's, but this information is under windows.
Is this possible under OS X?
Posted Mon 27 Apr 15 @ 5:41 pm
Posted Mon 27 Apr 15 @ 6:12 pm
Hey guys!
Is it right that I canĀ“t use the SX2 with a 7.X version of virtual dj until today?
Is there any solution in progress or do I have to upgrade to 8.X ?
Thanks for your help!
Posted Mon 04 May 15 @ 5:57 am
The SX2 is not supported in version 7,so you will have to use VirtualDJ 8 with it.
Keep in mind that both versions can co-exist, so you don't have to uninstall version 7 and you will still be able to use it anytime you want.
Posted Mon 04 May 15 @ 6:04 am
Hello DjDad, you posted on 18th Sep 2014, there will be a mapper vor DDJ-SX2 for VDj7 soon availabe. Now, more than a half year is over and i wanna know how's the status about this issue? Thanks and regards, Armin.
Posted Fri 08 May 15 @ 7:01 am
There will be no mapper for V7.
At least, not an official one from Atomix.
Posted Fri 08 May 15 @ 8:47 am
armolnar wrote :
Hello DjDad, you posted on 18th Sep 2014, there will be a mapper vor DDJ-SX2 for VDj7 soon availabe. .
Never said support will be provided for version 7. Care to point my post ?
Posted Fri 08 May 15 @ 10:01 am
Hi guys,
Might be wrong thread but cant get video sampler with VDJ 8 to work with Pioneer DDJ SX? Video output is perfect but none of my samplers will work. They work perfectly with CDJ400s and CDJ-2000s with stand alone mixer. Any suggestions?
Posted Fri 08 May 15 @ 1:23 pm
Thanks djdad! ;-)
Posted Tue 12 May 15 @ 5:04 am
pcroke wrote :
Hi guys,
Maybe you have the SAMPLER knob down ? Keep in mind that the Volume (Master or per Slot) of the Sampler affects the brightness of the Sampler Video Output.
Posted Tue 12 May 15 @ 8:54 am
Hi guys,
The last time I messaged I was told that the team had an sx2 for just after the start of May to carry out a native mapper with all glitches ironed out.
I was just wondering how this was getting on.
Serato is driving me nuts lol
Cheers
Iain
Cheers
Iain
Posted Sat 23 May 15 @ 6:40 am
The GAIN knobs issue has been recently addressed, so not sure what you mean by "glitches"
Posted Sat 23 May 15 @ 7:56 am
Hi guys
How did the VDJ team get on with a native 'official' mapper for the sx2?
Cheers
Iain
Cheers
Iain
Posted Thu 04 Jun 15 @ 10:54 am
so, i thought that i would plug in a give vdj and the sx2 a go with this latest build.
nothing has changed for this controller. disappointing to say the least!
platters still show a track playing when its not, cue buttons lighting up then not then they just start flashing..... and the list goes.
the sx2 is one of the most popular controllers out there yet vdj are not focussing on making this work as it should.
for me vdj8 is a great programme. perfect for what i do. works perfect with my pioneer wego 3 and sep c1. why not the sx2?
i really hope something happens and there is a full native bespoke mapper released asap. i can see vdj users having to move over to serato which would be sad.
yes i no this is a bit of a rant but its something i feel quite strongly on.
fingers are crossed!
Iain
Iain
Posted Thu 04 Jun 15 @ 2:00 pm
