ksavage1981 wrote :
Is the demo unit different to a standard unit then? As the SX2 has been out for some time and surprised some one hasn't bought one, as looks like a great controller.
No, it's not different.
New controllers get released every few months. Not all staff members need a new controller at the present time ;)
Personally I use an MC6000 (as small factor unit), an SX (as middle factor) and an SZ (as large factor)
Something similar goes on for everybody else. So, it's up to Pioneer to send a unit to provide support for it, and that has been the case with almost all controllers that don't ship with VirtualDj.
The rest information you asked for is confidential ;)
Posted Wed 14 Jan 15 @ 5:50 am
Yes, it works well. The beauty is that you can map the buttons etc any way you want.
I have an issue with the gains and their interaction with the software gain but it could be my prototype definition and mapper that is the problem :)
Keith
Keith
Posted Wed 14 Jan 15 @ 6:23 am
Hi All, I have just acquired a unit. Need help for fx sections. How can I assign different multiple effects on fx1 & fx2 sections with 3 buttons respectively? At the moment I can only assign & trigger 1 effect. For example I want to trigger FX1 section (button 1- Reverb, button 2 - Echo & button 3 - Phaser). FX2 section (button 1- Video Transition, button 2 - Video Effect, button 3 - Milkdrop). Gratitude for help.
Posted Thu 15 Jan 15 @ 1:07 pm
[SHIFT] + [TAP] to enable Multi Effect mode (toggles between Single and Multi) for left and right decks where you can set up 3 different effects for each FX1 and FX2.
Read more in DDJ-SX VDJ8 Operation Guide pages 10-12:
http://www.virtualdj.com/documents/Pioneer%20DDJ-SX%20VirtualDJ%20Operation%20Guide.pdf
Posted Thu 15 Jan 15 @ 9:19 pm
I just bought a pioneer ddj sx2 and it arrives with me on Tuesday next week. Can virtual dj 7 be used with it atall? I do use serato for recording my trance sessions.however I like virtual djs ability to analyse you're whole harddrive and be able to pick any track out where with serato you have to make crates.i do a few party's and weddings sometimes and if someone asks for a tracks I can just find it easily.can someone let me know if virtual 7 or higher not vdj 8 tho.can be used with ddj sx2 thanks.i got 2 weeks before my next gig.
Posted Sat 17 Jan 15 @ 6:37 am
As per the other thread you asked in version 7 is not supported
Posted Sat 17 Jan 15 @ 8:30 am
Bug in the DDJ-SX2 mapper?
Turn on KEY LOCK - the button is lighting.
Press SYNC button or move the pitch fader in the skin away from zero.
Press and hold the KEY LOCK button for more than 1 second to smoothly reset the Pitch - The button is flashing during resetting.
After slow pitch reset is light on this button off, although the key lock is still on.
How can I fix this?
(DDJ-SX2, VDJ 8 build 2126.911, WIN7)
How can I fix this?
Posted Tue 20 Jan 15 @ 10:56 am
Should be fixed in builds ending at xxxx.914 (or higher)
Launch VirtualDJ 8, leave it running idle for a couple of minutes and relaunch. Verify the updated build in the Config window.
Posted Wed 21 Jan 15 @ 1:50 am
Hello, when i touch any Jog Wheel Outer or OnTop,
The Cue button automaticly enables itselfs.
I didn't got this on a previos version.
I'm using build: 2126.917
Hopefully someone has a Tip :)
Posted Wed 28 Jan 15 @ 1:14 pm
by Cue buttons i suppose you mean the Pre-listen buttons, correct ?
If that is the case, then you can disable this behavior by changing the setting autoHeadphones to No or on Load (Config->Options tab)
Posted Thu 29 Jan 15 @ 12:22 am
Hi guys.. Is there a support for DVS on DDJ-SX2 yet?? I am using a mac pro and TT1200m3d
Posted Thu 29 Jan 15 @ 11:31 am
Recently just got the DDJSX2 after using the Ergo If I buy the license for VDJ as I'm not liking the SDJ very much would I still need to use external speakers as I can't seem to get any volume working with speakers or headphones when everything is turned up ?
Posted Mon 16 Feb 15 @ 8:14 am
That's the general idea with external hardware which has an onboard audio interface.
Rather than using the consumer grade audio in your computer, you use the audio from the kit you paid good money for, and plug speakers into that. :-)
Posted Mon 16 Feb 15 @ 8:55 am
However, if you purchase a PLUS license for your controller then yes you will be able to assign your computer's speakers as the master output of the sound if you need to (e.g. for practice at home)
Posted Mon 16 Feb 15 @ 11:43 am
Have any of the updates addressed the gain knobs? I'm still having issues with them, and wonder if I just need to reset something.
Posted Thu 19 Feb 15 @ 1:50 pm
No, they're not that accurate and quite jerky.
I don't really like the way they are but until Atomix get a demo unit (if one is still coming of course) I doubt anything will be fixed.
They work far better in Serato but the rest of the software is crap!
Posted Thu 19 Feb 15 @ 3:26 pm
Agreed. I gave Serato a chance, but I dislike so many things about it. Hopefully Pioneer will hand over a demo unit soon.
Posted Thu 19 Feb 15 @ 5:53 pm
I was going to order the ddj sx2 just after Christmas as wanted to upgrade my ddj sx. But after reading the forum and this post decided not too. As don't see the advantage at the moment with vdj. Thanks for the updates and information regarding the ddj sx2.
Posted Fri 20 Feb 15 @ 4:48 am
There isn't that much difference between the two units. VDJ doesn't do anything with the flip buttons, so really the only advantage is the (apparently) better sound card.
The colour pads are nice, but the VDJ implementation at present is really basic. You can of course program the pads yourself but it's not that easy. I have done some work on them to change colours and add blinking which is an improvement.
Posted Fri 20 Feb 15 @ 12:16 pm
Wait, hold up... There is no way to control the pad colours short of going into the code? Is this the case on the SZ as well or has it been addressed on that side with the native support? What is the basic support included? Just curious as the SX2 will most likely be my next controller once they get some of these glitches sorted out and get an official map released.
Posted Tue 24 Feb 15 @ 9:47 pm
