In the video how is he scrolling left/right ? @5:11 would be one example, my touch pad has H scroll but it doesn't work with V8.
Posted Mon 01 Dec 14 @ 8:20 am
Finally you see what I mean Groovin, this has been what I've been talkin about this whole time.
VDJ doesn't make the anchor a down beat like other software does. Either you get lucky and it works or it becomes painstaking task.
Something isn't right in my opinion or I'm doing something completely wrong here.
Posted Mon 01 Dec 14 @ 8:39 am
Having another go now, it seems that you need to quite selective about where you put the anchors.
If you take care/time, it is possible to get the "four shades of gray" in the correct place/order.
The thing is...........the ideal place for an anchor won't necessarily be "on the one".
VDJ needs to be smart enough to keep track of where the count is, based on where you are/what's gone before.
Posted Mon 01 Dec 14 @ 8:58 am
So is there a work around cause I know for myself it'll always be on the one.
Shouldn't take me a half hour to 45 minutes fighting with a program that thinks it's smarter then me when it clearly isn't.
I feel that when I place an anchor it should be the one or my down beat yet VDJ tells me it's not and throws everything outta wack.
I'm gonna give it another go again tonight but this is really frustrating 😡
Posted Mon 01 Dec 14 @ 9:06 am
Posted as a bug in the 8 bug report forum.
click me
click me
Posted Mon 01 Dec 14 @ 9:35 am
Thanks bro!!
Hopefully something good comes out it 👍
Posted Mon 01 Dec 14 @ 9:52 am
