Hi,
I have this song on my computer - I was wondering if I want you to by Weezer.
It shows up twice in the search.
When I try to load one, it throws an error, when I load the other, it loads properly.
How can I solve that?
Posted Sat 06 Sep 14 @ 9:20 am
have you try with windows media player to see if it's not the file wich have a pb
Posted Sat 06 Sep 14 @ 9:33 am
Clean your database. In theory that should remove any broken links (if that's the issue).
Check the tag editor to see if the file is there or not.
Posted Sat 06 Sep 14 @ 10:05 am
