when i save the settings in vdj8 does that go in a files someplace that i can transfer to a backup .
also what exactly does it save is it just the audio setup or all the settings?
Posted Wed 27 Aug 14 @ 5:21 pm
ALL setting are kept here,
Documents\VirtualDJ settings.xml
yes you can back them up, in fact if you get beta builds it's recommended.
Posted Wed 27 Aug 14 @ 5:50 pm
yes thanks i understand that ...
but you can give names to the setup on the audio config page and save them.
i wondered if that was a separate file from settings.xml
Posted Wed 27 Aug 14 @ 7:33 pm
you can create as many audio profiles as you want and save them from Config->Audio tab
The profiles along with all your other settings is saved in the same settings.xml file.
Posted Wed 27 Aug 14 @ 11:31 pm
thanks
Posted Thu 28 Aug 14 @ 4:04 am
Unless I am mistaken, It doesn't seem save the video delay options per profile.
I use widi and there is a slight lip sync delay so I use different delay settings based upon what video system I attach my widi receiver to.
Any help appreciated.
Posted Wed 24 Dec 14 @ 9:55 am
I have created a backup programme that backs up and restores settings.xml - now I can have multiple settings to call at will.
Posted Tue 30 Dec 14 @ 3:40 am
i m doing some changes in virtual dj 8 like changing skin an some settings relate to the bpm and some others settings but when i close my virtual dj window and start virtual dj the settings are not remaining same like virtual djversion 7,7.1 home free
Posted Fri 13 Jul 18 @ 8:15 am
You need to check permissions for the VDJ directory. Make sure you have permission to write.
Posted Fri 13 Jul 18 @ 8:54 am
BTW: If you still use VirtualDJ 7 then this thread is irrelevant to your case since version 7 is using the Windows Registry to store settings.
Therefore please ask for more help on the appropriate forum, or better yet, upgrade to VirtualDJ 2018
Posted Fri 13 Jul 18 @ 1:45 pm
