This may or may not be the right forum for my question but, Can someone tell me how set the VDJ8 configuration to operate my Pioneer DDj-SR. I can't seem to get my configuration right to make my dj controller to play the way it supposed to. When I start the program it shows the Pioneer controller in sound card, but should my output be on speaker? or speaker/headphone? then what do i do with the drop down boxes?..... For some reason i don't have this headache with VDJ7.
Posted Tue 26 Aug 14 @ 11:04 pm
Hi,
which OS do you use...?
Posted Wed 27 Aug 14 @ 1:31 am
If you click on the controller image in soundcards VDJ should auto adjust all the settings to work with the SR.
Posted Wed 27 Aug 14 @ 4:44 am
For windows:
Posted Wed 27 Aug 14 @ 2:41 pm
Thank you, I'm using Mac , ill try the set up again that last i did it like you suggested and only one side played let me try it again. thanks
Posted Wed 27 Aug 14 @ 5:31 pm
If clicking on the "special" AUdio button of the Pioneer DDJ-SR doesnt route the sound properly (Master and Headphones) read this page ... https://virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html (scroll down to the "For Mac OSX" section)
Posted Wed 27 Aug 14 @ 11:22 pm
I am having this problem. Ddj-sr not connected and failure to initialize ASIO drivers in VDJ8. I have sound through the controller, all pads show they are working, yet they control nothing in/on the program. What have I not done correctly?
Posted Wed 08 Oct 14 @ 10:21 pm
I'm using windows 7 premium.
Posted Wed 08 Oct 14 @ 10:23 pm
