Hi
I'm sure I read somewhere a while ago that VDJ could look at the track you're playing and offer some suggestions about the next track you could play? I would imagine VDJ would look at the history file and list all the tracks I'd previously played after it. Is this the case or did I dream it!?
It's quite frustrating when you're playing something and think, " Aah, i played a good one after this a couple of months back, but I can't for the life of me remember what it was. now I'll need to go through the history, try and find the date it could've been and scan through the playlist" not a good plan when you've only got 4 mins and there's a chance you could eat up 3 mins searching for an elusive track!
Thanks
Thanks
Posted Sun 24 Aug 14 @ 4:39 pm
This is called Live Feedback.
It isn't a local function. It requires an internet connection and provides suggestions from other DJs.
(But don't know what the source of this suggestions is)
Posted Mon 25 Aug 14 @ 6:27 am
Ah but Live Feedback is based on what OTHERS have played. DJ Lee wants VDJ to remember tracks that he played himself.
Posted Mon 25 Aug 14 @ 6:45 am
I know, and I wrote exactly that in my next sentence ;)
So to answere his question: No, currently there is no such function.
Posted Mon 25 Aug 14 @ 7:07 am
Thanks for your comments here guys, I'm not sure why I thought it was a VDJ function? I was thinking about this further last night and might design something in excel using VBA that looks at the history folder and searches depending upon what track title I enter.
If I'm successful I'll post a link to my creation!
Perhaps a development in VDJ8?
Posted Mon 25 Aug 14 @ 7:31 am
There is a plugin from 2010 called DJ Patterns which does exactly what you want - but obviously only for licensed users.
https://virtualdj.com/addons/10780/DJ_Patterns.html
Posted Mon 25 Aug 14 @ 7:50 am
But doe it work with 8 or is that even. Factor here??
Posted Mon 25 Aug 14 @ 10:07 am
The really comes down to proper tagging of files.
If you tag you files correctly you should be able to find whatever songs you are looking for - even after a couple of months
You can use the :
Star Rating system
Color code files
Comment field
Grouping field
Year field
Genre field
Custom field
You can use the :
Star Rating system
Color code files
Comment field
Grouping field
Year field
Genre field
Custom field
Posted Mon 25 Aug 14 @ 11:42 pm
Not Long ago we had something called Genius (I think in Version 6?).
This was a nice feature, what did exactly this.
The songs suggested based on your own history. I would be glad, if we could get it back.
Greets
Music234
EDIT:
Sorry, it was Version 7 / October 2010:
Database Management:
• new GenuisDJ algorithm
• new FileInfo window with multi-files tag and rename
• save to ID3 tags (or mp4 tags) option
• new browser fields (composer, rating, custom fields)
• support for nested virtual folders
• easy drag-n-drop management of virtual/favorite/smart folders
• automatically renew and manage Netsearch DRMs before it expires
• new zoom mode for temporary fullscreen browser
• new integrated audio preview of browsed songs
see Virtual DJ history!
Any Chance we could get this back?
In the Manual you could read this:
GeniusDJ – shows recommendations from your own library based on what you are currently playing.
Greets
Music234
EDIT:
Posted Tue 26 Aug 14 @ 3:45 am
GeniusDJ too wasn't an offline function.
See here: https://virtualdj.com/forums/142821/PC_Version_Technical_Support/Genius_DJ_feature.html?search=Genius &page=1.25
Posted Tue 26 Aug 14 @ 3:53 am
You're wrong.
Look in the Manual:
Look in the Manual:
Posted Tue 26 Aug 14 @ 3:59 am
If it was offline, this statement would be totally wrong.
But since it came from the support, either the manual is wrong or the support
Hvelez wrote :
I was told by the support team that the genius sever is being worked on and they don't know for how long .
Posted Tue 26 Aug 14 @ 4:02 am
Take a look in the full Version guide took from here:
https://virtualdj.com/wiki/PDFManuals.html
Page 5:
Volumes – shows the File System navigation option to access all hard drives connected
Desktop – shows the File System navigation option from the Desktop level
NetSearch – show the files cached from NetSearch, and provides access to the search engine for our Premium Membership audio search and publicly available search to find those last minute requests. You can then instantly stream search result directly from the Internet source.
** To learn more about this feature and additional features that compliment the NetSearch capabilities, visit our website at virtualdj.com.
and yes I know that works offline based on my own db.
anyway. It would be great, if we could get that feature back...
EDIT:
I put this on the wishlist. Christmas is around the Corner XD:
https://virtualdj.com/forums/193107/Wishes_and_new_features/offline_genius_ala_Version_7_0.html
Page 5:
EDIT:
Posted Tue 26 Aug 14 @ 4:12 am
