Is there a way I can assign one of the custom buttons to show a video preview screen instead of the rotating deck? This would be absolutely awesome, if its possible.........
Posted Fri 22 Aug 14 @ 5:49 am
Either you use a skin that is designed for VJ's or use the standard skin's video panel.
You could map a button that it switches to the video panel if pressed. Or... customize the whole skin to your needs.
Posted Fri 22 Aug 14 @ 6:08 am
I could just press the VIDEO tab on top of mixer for the standard video, but I was really after large preview decks, keeping the main mixer...."VDJ8 but by Fruit" is an amazing skin for customising, but the default is PERFECT, except..... :-)
I wish I had the skills to make my own skin, maybe I can find a "tutorial on skinning for non-coders"!
Posted Fri 22 Aug 14 @ 6:21 am
you can try the skin "jmf36000"
the next update is for the next week, with big scratch, etc
Posted Fri 22 Aug 14 @ 10:00 am
You can have a copy of this skin if you like, Dan was good enough to make this to my specs and for me it's the ideal skin for anyone doing video work!
Posted Fri 22 Aug 14 @ 12:35 pm
That looks very nice! I need more knobs though, at the moment I'm tweaking the look of Fruit's VDJ8 skin - its the nearest to my ideal I can get!
There must be a market for bespoke skins to order, from a submitted screenshot ;-)
Posted Fri 22 Aug 14 @ 12:43 pm
