Topic: Delay in Headphones
I am brand new to DJing and the equipment. I have a Denon MC6000MK2 controller. There is a delay in the headphones. I am running VDJ 8 Pro. Is there something in the configuration of the software that would fix this? Or is there a setting on the controller that needs to be changed? Thanks in advance for any help from the forum members.
Posted Mon 18 Aug 14 @ 5:50 pm
Mac? PC?
Your VDJ 8 audio config settings are....?
My audio config says Speaker/Headphone, Internal Soundcard, and there is nothing selected for input such as timecode or line input. Is that what you mean?
Don't you want to use the soundcard in the MC6000? Do you see the option to use the MC6000, in the card section? Why are you using the internal soundcard?
